Seat upgrade for 19 power wagon
Grimlock
I want to upgrade the seats on my PW with leather and heating/ cooling. I can go the Katzkins way or get some factory seats. I can get a set of TRX seats but don't know if they will work. Fitting them isn't an issue but I have no idea what all else aside from the actual seats are needed.
Looking for advice on each option. They will but cost me about the same. Only reason for going oem is the TRX seats are a nicer style than mine shape wise and of course keeping it factory.
TRX seats won’t fit. 1500s and the HDs use different seats and they don’t mount the same.
As stated "Fitting them isn't an issue but I have no idea what all else aside from......"
Ok, so long as you know you'll be cutting and welding seat brackets.
There's a lot of electrical work involved, including that the heated seat modules aren't compatible between the trucks, and are installed on opposite sides of the cab. You'll also need to build a PWM controller if you want the cooling function to work. https://www.ramforum.com/threads/5th-gen-seats-into-a-4th-gen.156623
