s2 baja design fogs..unreal!
dieselbeef
havent installed them yet..gonna be a project since i have a ranchhand bumper....theyre tiny little things..way smaller than i thought but omg the light they put out is crazy bright....218 on amazon only because no one else had em in stock...the quality is outstanding...highly recommended....
How about a link?
cant vouch for those..ive got those brackets with my ranchhand..ill makethe little square ones work...
gotta say..theyre smaller than i thought....but man theyre bright
Some thoughts
448033 kit comes with mounts nut no bezel. Leaves an open area /hole around the lights?
4480421 kit includes 448042 bezel and 448043 lights. Bezel looks weird, not like the factory.
If you have a Tradesman I suppose these work.
If you have a Laramie you need a bezel to fit the BDs and retain Park Sense sensors. BD does not have a part number for that. What to do?
Hers a pic of a Laramie with BD fogs from their website which tells me they did it. I'll have to call them again.
Some thoughts
what truck do you have and what kit do you want to add?
I have all the info about what parts you need to add the squadron lights (not the s2) to a tradesman truck.
you need the factory fog light bracket and the correct bezel
My 2020 3500 Laramie is in my signature+
Want to replace factory fogs with BD fogs but have to have a replacement bezel that accommodates the BDs and includes mount holes for Park Sense sensors. I can't find that on their site but they have a website picture of a truck equipped with what I need so I have sent them an inquiry. I know I can buy the proper bezel aftermarket but feel that BD should provide what they advertise.
My posts here were seeking help if anyone has gone through the same problem. I know the Tradesman owners have not as they come with a blank bezel (no fogs).
Appreciate and thanks for your offer but it's not a Tradesman.
If you already have fog lights they drop right in, assuming you get the style that is made for the type of fog lights your truck has.
The S2 kit replaces LED fogs
The squadron kit replaces halogen fogs
if you get the correct kit, you will re use your factory bezel.
I had no park assist or fogs so I got a halogen no park bezel for the squadron kit. (I have an aftermarket bumper but it accepts factory fog hardware and bezels)
Hope this helps
No help - the pictured bezel has no mounts/holes for Park Sense sensors
I know that --
You said, "Hope this helps". I was just responding that it didn't help
But.. It did help.
I explained that you would re-use your factory bezels. Whatever style they might be, it doesn’t matter.
You will retain your factory bezels as long as you buy the correct kit for the bezel you have, which I also explained.
I'd like to do these as well. Since I have a Limited it would be the S2 kit for LEDs. Question is I wonder how bright these actually are? I like to use my fogs for supplemental light so it would be white for me.
That is the light kit for trucks equipped with LED headlights. It comes with the bezels needed to add the squadron to your truck.
If you want to go with a kit that isn’t designed for your bezel style then yes, you need to buy bezels.
That may be harder to understand for some people, though
Fwiw, I paid $18 for the bezels I needed from a mopar dealer online.
