Wheelz
Does anyone know if the inner rotor and caliper on a DRW is the same as a SRW? They both look the same as both use a drum brake for the E-brake and the same rotor and 2 piston caliper.....I'm not quite sure on the caliper size due to the towing differences. The only difference I can see is the DRW hub extension for the outer wheel.
I'm going to experiment on a 6 piston caliper and rotor kit but they only list for SRW for 11.5" rear ends. Since I dont have Max Tow (12" rear end) on my DRW I think it'll work. I found a common Mopar part number for the rotors, both SRW and DRW.
