kobra
Hi all,
I searched but didn't see threads about noise other than rattles. I don't have rattles but do believe I have above normal road noise.
2020 RAM 3500 Limited HO, SRW. So far, still stock tires and wheels. The only addon is a Retrax bed cover.
I have hearing damage so I know I am overly sensitive to road noise. So, to test, I run apps on my iphone, one called "Decibel X" and also another called "Niosh SLM"; both return similar results so I just use the first one for convenience. I understand that these are apps on an iphone and not an SPL meter and that they are not calibrated, but I guess my thought is that it's the same phone with the same apps so the results should be consistent even if not completely accurate. I'm open to being challenged on this and will get an SPL meter if that is needed.
Some tests: (all tests with same phone held at ear level above center console)
-prior truck, 2016 RAM 2500 Limited (6.7/68rfe). Apps test about 85db noise.
-test drive in summer on 2020 RAM 3500 Limited (very similar but we ordered to get the navy interior and air suspension; otherwise the same). Apps test at about 76db. That was a quiet truck!
-new truck, 2020 RAM 3500 Limited, apps test at 83db. Better than the last truck, but barely - where is my noise reducing glass and ANC?
-some wind noise observed, so trip to dealer to adjust both front doors (my last 3 RAMS have all needed this, sigh). They also confirmed that the ANC is working properly. Retest, apps show 81db. Better but not by much and not even close to the test drive in the summer!
In the 5thgenrams forum, there are a few long threads about the 1500 RAMS and how there have been some noisy ones amongst the mostly really quiet ones. Some members there have gone all out with Dynamat, etc. I am not interested in doing that. But, one thing that stood out from that forum is that some have found that the rear cab vents are noisy when open and contribute greatly to road noise. There are some suggestions there on how to build some covers that apparently can really help.
Given all the hype from RAM about the new models being 10db quieter than prior generation, and the testing from TFL trucks and others, I guess I expected to get a much quieter truck.
The dealer said they are willing to keep working on it, but they say it could be the cold weather and the stiffness of rubber cab mounts, etc. I can't test in the warm weather anytime soon so cannot confirm whether the cold weather is the issue or not.
My questions to this group are:
-Has anyone else noticed excessive road noise?
-If so, does anyone have ideas that have helped to reduce the noise?
I would like to get back to the quiet ride of the one I test drove in the summer, and I'm sure not there yet.
Thanks in advance for any feedback and suggestions!
B
B
