Retractable running board lighting.
Xflight29
Evening, has anyone added lighting to their factory installed retractable running boards? I would like to add them, so they illuminate when they are deployed for increased visibility and safety.
no but Seems like if you tied them into the puddle lamp circuit they would fade on/fade off and be pretty slick
I have not done that, but I do play with LEDs.
Because I mostly work with 24 volt, I have been experimenting with these 24 volt strips with a built in driver - so they can connect directly to a 24 volt battery vs needing a separate unit. When I say directly - I mean through a fuse.
This is the 12 volt version - have not used them but the concept is the same.
So far just work table testing but they throw a lot of light. A couple of different colors red in one photo. In another
- 3000 K on the left
- 4000 K in the middle
- 5000 K agricultural on the right ( very high quality spectrum - similar to HID )
All other lights in the garage are off when these are lit up.
For fun a small weather resistant combo breaker / switch I am playing with.
These LED strips and drivers are some of the few that I have found that have an extended temperature range that is similar to a vehicle. You will need to protect them from water with some potting.
