Replace Resonator with Muffler
dieselscout80
Has anyone replaced their resonator with a muffler like the Magnaflow 14162 or something like it?
If so how does it sound especially compared to the factory setup?
You likely won't notice a bit of difference as the stock resonator is a straight through unit just like that Magnaflow. Most people either swap the muffler with a straight through unit and leave the resonator or leave the stock muffler and delete the stock resonator. Both good options for a decent sound increase.
I need to measure the stock muffler and resonator. But, what I was thinking of doing is keep the resonator, cut out the muffler, and put a flowmaster 70 series and the resonator where the factory muffler was. Then, redo the tailpipe.
Try just replacing the resonator with a straight pipe first. You may like it. ;)
If not, then you at last have the resonator to install with the new muffler. And you will have the tail pipe done.:cool:
What diameter exhaust tube is the factory system is it 4”?
