Repinning wire harness question
Ramlink
Some kind of rodent did a number on a wiring harness in my truck. This is in the front bumper drivers side. I’m missing my front parking sensors and one fog light. Unfortunately the damage is on the side that leads back to the main branch of wiring not the side heading towards parking sensors. My question is does anyone know exactly what style of pins are in this connector? My plan is to repin just the broken wires but there seems to be a lot of different pins I was going to order a multi pack on Amazon but not even sure that will have it. If I can figure that out I guess I’ll cut the connector out and hardwire it all with solder and heat shrink. Thanks for any input.
2022 Ram 3500 (srw,bighorn,HO diesel)
Do you know if this connector can even be de-pinned? Some pins are molded in. If you can get a pin out, it may be easier to identify the correct contact.
You have enough wire there that if it were me, I would just solder and use weatherproof heat shrink. Repinning the connections may cause other issues if they are not inserted properly or are slightly different in size. Good luck, getting rid of the rats/mice is a lot harder! Also, leaving the hood open will deter them if you don’t use the truck often.
