Does anyone have pictures of this upper dash tray removed? I’ve removed the 2 screws and pulled up and back and was able to release the clips on the front, but the tray won’t come out. I’m trying to mount a 67designs rail in it
It does not come out its molded in if im not mistakenDoes anyone have pictures of this upper dash tray removed? I’ve removed the 2 screws and pulled up and back and was able to release the clips on the front, but the tray won’t come out. I’m trying to mount a 67designs rail in it
The tray is part of the unit, it's not removable, at least not unless you cut it out.
I have the 67 designs base currently, and I'm not a huge fan, especially if you're mounting anything remotely heavy. I think there is a better option with the ICS Fab (link).
I have the same mount, with the little arms. The issue is that the head unit area doesn't have enough of a base so it wiggles. I initially only had the head unit of a FTM400 ham radio, and recently added a 8" Garmin. It holds, but it has some wobble for sure.Thanks. I’m still going to give the 67 designs rail a shot. Is that what you have that isn’t working well for you? What are you mounting?
