RECALL: 2019 To 2020 Ram 3500, 4500, & 5500 Chassis Cab With Cummins H.O.:
redriderbob
Co-Editor & Ram Guru!
Staff member
Age
41
Metro Detroit, Michigan
RECALL: 2019 To 2020 Ram 3500, 4500, & 5500 Chassis Cab With Cummins H.O.:​
No Low Oil Warning Could Lead To Engine Fire...​
Stellantis (FCA US, LLC) is recalling certain 2019 to 2020 Ram 3500, 4500, and 5500 Cab Chassis vehicles equipped with the 6.7-liter Cummins inline-six H.O. turbodiesel engine. According to the recall notice, the engine calibration software may not warn about low oil volume.
I will chase my dealer up , living in the land down-under could be a little hurdle ??
You could always check your oil level manually on occasion (highly recommended) and problem solved.
Yeah, but it can’t hurt to have catastrophic coverage if you know what I mean.
I definitely do check mine often.
Daytime running lights , is there a way I can turn them off while the vehicle is running ? More than happy to drive with them on but can be a pain when I wish to pull up in the middle of nowhere for an hour or so sleep in the dark.
There should be a setting in the radio setting to turn it off. With that said some countries make them mandatory so you may not have that option on yours? You can surely add it with AlfaOBD though. There are many threads on the ALfaOBD app and what it can do if you are not familiar.
Thanks for the info mate ,cheers
