Rear air spacer/puck size.
BigTim
Ok, let's see if this makes sense. If I am installing a 2" front, 1" rear Thuren lift, would installing a 2 or 3" spacer in the rear allow for a softer ride with the extended links installed? If I am thinking correctly, just the links will result in a rougher ride, adding a 1" spacer would essentially put it bak to a "stock" setting, adding a 2 or 3" block would allow the same height with less pressure in the bags??? Thoughts...
I don't think so. I have the 2" front and 1" mid rate coils and the ride is very good. Extended links with Rear Track Bar also.
I don’t think the truck would ride any different with taller spacers and less air in the bags, I haven’t noticed any ride quality difference from standard height to alt trailer height that lowers the rear a little more than an inch (less psi in the bags).
