Re-activate rear seat heaters
tuckjack
Louisville, CO
I removed the driver side rear seat in my 2021 75th Anniversary Power Wagon to install a Goose Gear seat delete. In the process of removing the seat, I disconnected it from the cord that powers the heater. As a result, it seems the circuit is not complete, as the heater for the remaining rear seat does not work. Is there a dongle available or a way to connect the circuit so that the heater will work in the remaining seat?
@Jimmy07 I wondered whether this might be something you know the answer to.
Thanks for any and all help.
The rear heated seats module is in the driver side seat section, so you’ll need to remove that along with all the wiring that leads to that main seat connector you unplugged, and install it somewhere in the truck.
Does that rear seat module have any effect on the heated steering wheel? They are replacing that module in my truck to try and get the heated steering wheel to work. I am no buying it but that is what the engineer at ram wanted to do.
No. The front heated seat module under the driver seat handles the steering wheel.
thats what i thought but they are insisting on replacing the rear one now. I don't think they know what they are doing at this point. its been in and out of the shop since april 4th for this.
