BadKarma
Hey yall, wondering if any of you have experience installing the grille guard. I attempted too today after scoring one. Installed the brackets with the bend facing out and the tow hook holes don’t line up but the guard mocks up. With the bends facing the other way all the holes line up but the guard is like 3” off from the mounts. The instructions say I’d need to drill out the tow hook holes if using the supplied bolts but using my bolts on the truck secured fine without using the supplied ones. I guess I’m asking the question I kind of already know the answer to and that’s to use the half inch by 4 inch long bolts supplied by ranch hand however, I got the drill guard secondhand did not come with the half-inch by 4 inch and was hoping to use the factory bolts because the way I interpret the instructions is if I choose to use the ranch and bolts. Direct quote from the instructions. “When you try to put the bolts back on, they will seem to be short. If you decide to use the 1⁄2”x 4” bolts provided, you will need to drill out the holes in the frame first.”
So I guess what I’m asking is do I need to drill out the frame even though I’m not using the supplied bolts
