Ramcharger wireless charging pad retrofit in 2023?
DeanKing
Has anyone installed part 82215150AG in a 2023? They do not offer an option of a wireless charging option at all on the Rebel. Yes. I realize this is a nitpicky first-world problem. The kit works on a 2022 but not a 2023. It appears the difference is that the 2023 no longer has a CD player so they moved the USB ports to the middle of that panel. If the USB ports are the same part as last year (they look the same) and the harness is long enough to stretch an extra 2 inches, it seems like it would work. Just wondering if any brave soul cared enough to risk the $300 on a non-refundable part to try it. I realize I would also have to find a plate or tray to fill the space where the CD player was on the replacement part.
There hasn't been a CD player available since 2019. My Rebel has the same panel that the CD player versions have, so the wireless charger would work just fine on it. I'll be adding it whenever I finally get around to it.
Does yours have the center located usb ports?
interesting. I am in the ordering process. I test drove one and it had the centered USB ports. So maybe the Mopar compatibility listings just haven’t caught up to 2023.
Yeah, they’re terrible at updating that stuff.
Even if yours does come with the centered USB ports you can still install the wireless charger, you’ll just have to also purchase the little cubby that goes where the CD player used to be.
I'm picking up a 2023 2500 Rebel this week and want to add the wireless charger as well. I spoke with the dealer and they said that they cannot add it because the code isn't available to activate the charger on the Rebel. Can anyone confirm this? Can I DIY with AlfaOBD?
You can DIY it with AlfaOBD.
