Rambox Gooseneck Questions
ACEd
Looking for options to put a Gooseneck hitch (B&W Turnover?) in a 2022 3500 SRW with Rambox
I have been told BWGNRK1320 is usable with Rambox but needs special template for 2021/2022 models
Question 1. Is this the best option and are there any other special needs?
Question 2. What is best way to route the Trailer Connectors INCLUDING Tow Mode Camera?
Any help would be appreciated. Best, Ed
Not sure if yotu have solved your problem , but I have just installed this setup in my 2022 2500 shortbed, B&W is the best setup and the wiring is mounted on the drivers side rambox above the bed light. The camera plug is on the rear bumper.
Thanks
Do you have factory wiring on rambox or did you add to drivers side rambox? If you added, what wiring kit? Picture?
As to camera wiring, are you going to try and relocate in bed or just try to live with it on bumper?
Best, Ed
Hopefully we are talking about the same camera. On the bumper on the left side of the hitch , is a flap that covers the plug in for a camera wire that you will mount on the back of whatever you are towing and it will replace the view in your rearview mirror, I am leaving it where it is. 41157 is the wiring and plug wiring harness part number.
Yes the TOW MODE Digital RearView camera - single FAKRA (spelling?) connector left side of notch in bumper - just wondering how you get enough slack in cable tied to bumper for gooseneck side to side movement without cable dragging on the ground. Thought about hanging with a spring but that would probably pull connector from bumper but would rather move to in bed like main trailer connector.
I would plug in and zip tie to the neck of the gooseneck . I sent photos in the notifying email. hope it comes through.
