Question for anyone with a Banks iDash?
How do I get a manual PID for the torque pro app to show lock status?
This is the PID I used in Torque for my 2016 2500 with a 68RFE. I created a new PID using these values and used a digital gauge to display it. There are 3 values returned on the PID and I translated them over to the following so it should show up as "Unlckd", "Lckng" and "Lcked" (appreviated so it fits in the gauge).
Not sure what years this will work with but it does on my 2016.
Thanks I will try tonight when I get home from work!
update. this worked . thanks so much
I will take a look. There is are so many options it's impossible to remember.
So interesting…I looked through every single gauge option yesterday. Didn’t see it. I get back in my truck today, fire it up, and I actually had several different options that weren’t there before…including the trans gear option. Weird.
I can see some of the options if I just put the ignition on. But some others only show when the engine is actually running.
So interesting…I looked through every single gauge option yesterday. Didn’t see it. I get back in my truck today, fire it up, and I actually had several different options that weren’t there before…including the trans gear option. Weird.I cn
Maybe that’s what happened. I also noticed that some more options populated when I went into settings and actually specified a vehicle make/model/engine.
Do you have any for VGT actual?
I posted below but i found that online and seems that ones with out a ModeAndPID do NOT work.
NameShortNameModeAndPIDEquationMin ValueMax ValueUnitsHeader
:Fuel Rail Pressure: CommandedFRP C016D(B*256+C)*1.45
0​
27000​
PSIAuto
:Fuel Rail Pressure: ActualFRP A016D(D*256+E)*1.45
0​
27000​
PSIAuto
:Fuel Rail TempFRT016D(F-40)*1.8+32
-40​
215​
FAuto
:TQ Conv Lock StatTQCLStat22B09BA
0​
275​
Auto
:Transmission Gear: CommandedXMSN GC22A09FA
0​
8​
Auto
:Transmission Gear: ActualXMSN GA22A0A0A
0​
8​
Auto
:DPF: Regen StatusRegen018BBIT(B:0)
0​
2​
Auto
:DPF: Regen TypeActive Regen018BBIT(B:1)
0​
2​
Auto
:DPF: StatusDPF Status018B(C*100)/255
0​
100​
%Auto
:Turbo: BoostBoost
170​
(D*256+E)*0.00453125
0​
35​
PSIAuto
:Charged Air Cooler Outlet TempCACT
177​
((B-40)*1.8)+32
0​
225​
FAuto
:DPF: Pressure GradientDPF Press Grad017A(B*256+C)*0.1
-3300​
3300​
mbarAuto
:DPF: Inlet PressureDPF In Press017A(C*256+D)*0.1
0​
6600​
mbarAuto
:DPF: Outlet PressureDPF Out Press017A(E*256+F)*0.1
0​
6600​
mbarAuto
:Exhaust PressureEx Press
173​
(B*256+C)*0.1
0​
6600​
mbarAuto
:EGR: CommandedEGR Comm
169​
(B*100)/255
0​
100​
%Auto
:EGR: ActualEGR Act
169​
(C*100)/255
0​
100​
%Auto
:EGR: ErrorEGR Err
169​
((D-128)*100)/128
0​
100​
%Auto
:EGR: TempEGR Temp016B((B-40)*1.8)+32
0​
255​
FAuto
:EGT: DOC InletEGT DOC In
178​
((((B*256+C)*0.1)-40)*1.8)+32
0​
2000​
FAuto
:EGT: DOC OutletEGT DOC Out
178​
((((D*256+E)*0.1)-40)*1.8)+32
0​
2000​
FAuto
:EGT: DPF OutletEGT DPF Out
178​
((((F*256+G)*0.1)-40)*1.8)+32
0​
2000​
FAuto
:EGT: Cat ConvEGT Cat Conv
178​
((((H*256+I)*0.1)-40)*1.8)+32
0​
2000​
FAuto
:EGT: Cat Conv OutEGT Cat Conv Out
198​
0​
2000​
FAuto
:Manifold Absolute PressureMAP
187​
(B*256+C)*0.00453125
0​
60​
PSIAuto
:NOX Sensor 1: Pre-CATNOX Sen 1
183​
(B*256+C)
0​
5000​
ppmAuto
:NOX Sensor 2: Post-CATNOX Sen 2
183​
(D*256+E)
0​
5000​
ppmAuto
:DEF Consumption CommandDef Rate COM
185​
(D*256+E)*.005
0​
328​
L/HAuto
:DEF ConsumptionDef Rate
185​
(B*256+C)*.005
0​
328​
L/HAuto
:DEF LevelDef Lev
185​
(F*100)/255
0​
100​
%Auto
:Run Time w NOX WarnRTwNW
185​
(G*(256^3)+H*(256^2)+I*256+J)/60
0​
500​
MinAuto
:Turbo: Commanded cm^2VGT Com
171​
25-(((C*100)/255)*.22)
0​
25​
CM^2Auto
:Turbo: Commanded %VGT Com
171​
(C*100)/255
0​
100​
%Auto
:Turbo: Position cm^2VGT Pos
171​
0​
25​
CM^2Auto
:Turbo: Position %VGT Pos
171​
(B*100)/255
0​
100​
%Auto
:Turbo: RPMTurbo RPM
174​
(B*256+C)*10
0​
660000​
RPMAuto
:Turbo: Compressor Inlet TempTurbo CIT
175​
(B-40)*1.8+32
0​
220​
FAuto
:Engine: Run TimeEng Run Time017F(B*(256^3)+C*(256^2)+D*256+E)/3600
0​
500​
HoursAuto
:Engine: Idle TimeEng Idle Time017F(F*(256^3)+G*(256^2)+H*256+I)/3600
0​
500​
HoursAuto
:Throttle Valve: CommandedTV Comm016C(B*100)/255
0​
100​
%Auto
:Throttle Valve: ActualTV Act016C(C*100)/255
0​
100​
%Auto
:DPF REGEN AVGTDPF AVGT018B(D*256)+E
0​
65535​
MinAuto
:DPF REGEN AVGD KMDPF AVGD018B(F*256)+G
0​
65535​
KMAuto
:DPF REGEN AVGD MIDPF AVGD018B((F*256)+G)
0​
65535​
MiAuto
:Main Injection TimingTiming015D((A*256+B)-26880)/128
-210​
300​
DegAuto
:Driver Demand TorqueCom TQ
161​
A-125
-125​
130​
%Auto
:Grid Heater ActiveGrid Act
165​
BIT(B:3)
0​
1​
Auto
:MPGMPG015E[010D]/(((A*256 +B)/14)/3.7541)
0​
40​
Auto
This one worked for me... With that said different year trucks seem to act differently or if you are tuned all those may be out the window
Thanks so very much this worked for my 2019 6.7 as well! Do you happen to have one for fuel rail temp as well as one for what gear your in? I know how to see what gear I am in on my gauge cluster but would like to see it in the App lol
Awesome! Let me get back to you when I get home this evening, I do have one that worked for gear both current and commanded. I don't think I ever had one for rail temp but I'll look. I'm using Ezlynk now so my tablet running torque is not currently in my truck. Once I tuned the truck several of the ones I was using stopped working. Tuning must alter some of those PIDs or something?
not to sure about tuning altering secerns. I have not got that far yet. One day I will turn her up. I greatly apricate your help! My pap is in his 80s and he drove Tractor Trailer all his life. I take him to local FleaMarkets and he loves watching the gauges. Of course I do as well!
