Sgtcuddeback
Picking up my truck today and wasn’t sure if the prep group comes with the ball and pucks. Anyone know
Thank you.You have to buy the ball kit separately.
Thanks, I am leaning towards the B&M unless someone has had troubles with itAmazon curt kit is the best value and curt is the same as the OEM one as mopar buys from curt….
B&W you mean?Thanks, I am leaning towards the B&M unless someone has had troubles with it
B&W most $$$ and is TALL
Reese is about the same price as Curt and I prefer over the Curt (Mopar) setup.
I do have a Curt A25 hitch that I absolutely love. Several other Curt products as well, cable adapters, drop hitches, etc. All solid products.
I will not buy another Reese product…. i have a lot of the older stuff but the last 2 reese products i bought have been terrible, i bout a 5” drop 2” shank rated at 6k it broke the welds with 1500lbs towing 300lbs tongue weight and the puck system to rail adapter was 1/8 out of alignment for my Reese 5th wheel hitch i measured the hitch it was exactly the right dimension the adapter was off i had to die grind the slots to fit the hitch as i needed it that day could not wait for the replacement also the T bolts to go in the pucks 2 of them were 1/4” to wide for the pucks so i had to machine them down after contacting Reese they refused to reimburse me or let me return the adapter even after agreeing there was an issue from the pictures i sent them
$300 or so in a nice carrying case. I like mine.Amazon curt kit is the best value and curt is the same as the OEM one as mopar buys from curt….
