Premium overhead console swap issues - help ?
dmhines
I wanted to add a tailgate button to my Truck so purchased a Premium Overhead console. My tradesan had the LIN BUS harness installed since it had the Uconnect Services buttons.
Here is what works:
Interior LIghts come on when Door Opens
Map lights go on/off on when buttons pushed.
TailGate Drop works.
The indicator lights come on in the ON/OFF switches
The uconnect services button works
What doesn't work:
The ON / OFF button to control the inteior lights ..
I found the wiring diagram for the connector from jimmy07 and all wires are in correct location except no sunroof wiring in my harness. Seems like the LINBUS does control all the lighting.
seems the interior lights should be controllable if they work with door open and close and not the buttons. They also come on when door unlocks via FOB so it must be BCM controlled.
Figured it out .. all working now .. in ALFAODB there was a setting for Overhead console Type .. Base or Premium .. I switched to Premium and now all the buttons working ..
Nice! Got a part # to the premium overhead console? Interested in doing this as well
Best to just find one on eBay with the color and buttons you need. That’s what I did. Paid $70 for mine. I don’t have a part number.
How hard would it be to add a USB port to an overhead console for a dashcam? Eliminate the hanging wire.
I assume the map lights have constant power to tap into. Or the rear slider harness should have power to tap into.
