lmoretti123
Anyone get creative with this open space? I was hoping to find an aftermarket solution that had a cut out for the lever but I haven't been able to find anything.
A bit confused by this question. I am assuming you do not have a Powerwagon?I was wondering if you have the electronic transfer case switches if you could order the center console that comes with the 75th Anniversary edition.
The Power Wagon I just ordered will have the electric transfer case buttons and not the floor shifter. So was wondering if a center console would fit. Since the 75th Anniversary PW has a center floor console was curious if it would be an easy add.A bit confused by this question. I am assuming you do not have a Powerwagon?
The center console is straight from the Laramie. You could order it in whatever color you would want though.
If you have a powerwagon you would have to remove or customize for the floor shifter.
There is a thread for this conversion at ramforum.com
I have heard...but never seen confirmed...that the seats of the 60 40 60 are different than the console seats. That may be a consideration also...or may not matter
