Yes there is an OEM manual sliding back glass, although I don't know the exact part number. There may even already be in your truck what's required for the heated and/or power sliding back glass if you're interested. Basically just replacing the glass and overhead console (where the sliding back glass switch would be) with the appropriate ones and plugging it in to a connector that's already there, just plugged into a dummy connector from the factory. And then changing the settings in AlfaOBD. You would have to add the motor for the rear slider if you do add that though, but the wiring is already there behind the rear seats below the center of the window.
