I am not due for the first oil change yet but will get close to a year in 3 months or so and will be at probably only about 5,000 miles max. So future oil changes will likely occur once a year in March. I see the Ram call for 10W-30 in normal temps and 5W-40 in cold. But I have seen a few people, like @Brutal_HO this morning say 5W-40 for hot temps. In other places I have seen the 5W-40 for towing only trucks. I am confused as to why if 5W-40 is for cold temps, it would also be for towing and hot temps? Obviously, I don't understand this well, but any explanation would be appreciated. Thanks.
If I will be running the oil for a year March to March, 90% of miles for towing, temps between 30 degrees and 90 degrees for @75% of the time. The remaining 25% of towing time would be 90 or above, maybe briefly as high as 110. The other limitation is that the oil change will be at the dealer so I may be limited to what they will provide? I may only use the dealer for the first oil and filters change if I can find someone local to help be the next time after that to make sure I do it right. But it is probably unlikely that will happen as all the folks I know that do their own oil and filter changes on these trucks live very far away from me.
