Is there a way to determine the final payload rating of your truck ordered, produced but not yet delivered from the Saltillo plant ? The build sheet does not include this information nor does the Window sticker.
Thanks for your help.
thanks. i was just trying to determine if i could get that number before delivery. You can get everything like build sheet and window sticker, but you cant get the payload or the estimated time of dealer arrival on line. I suspect it is somewhere, but maybe not available to the end customer until delivery.Your payload will be the GVWR rating minus the actual as built curb weight. The difference between these two numbers is your actual payload. Most specs you find are going to show max and minimum number. A low optioned vehicle will have more payload than a highly option vehicle.
Did you try plugging in the VIN on the site Brutal posted above? Mine showed up there the day that I got my VIN.thanks. i was just trying to determine if i could get that number before delivery. You can get everything like build sheet and window sticker, but you cant get the payload or the estimated time of dealer arrival on line. I suspect it is somewhere, but maybe not available to the end customer until delivery.
Brutal gave you the link to get your payload.thanks. i was just trying to determine if i could get that number before delivery. You can get everything like build sheet and window sticker, but you cant get the payload or the estimated time of dealer arrival on line. I suspect it is somewhere, but maybe not available to the end customer until delivery.
got it now. thanks for your advice.Did you try plugging in the VIN on the site Brutal posted above? Mine showed up there the day that I got my VIN.
