Pairing trailer tire pressure sensors
Hrxcrab
Just purchased demo 2023 2500 Limited. Had tire pressure sensors installed on a 8.5 x 16 enclosed trailer. I am unable to get these paired to the truck. Have attempted the process at least 10 times. Seems like it should be a simple. Anyone else had this issue or have suggestions before going to dealer? Thank you in advance.
I just installed sensors in my trailer tires and paired them with my 23 3500. I let 5-10 lbs of air out and each of them paired without issue.
Make sure you are at the latest version of uConnect 5. Some of the old versions made that job harder. I am at 27.46 on my 12" U5 system and the TTPMS pairs really quickly.
The only issue I've seen is when initially connecting my trailer the sensors dont read. I have to go into the settings, select a different trailer, then go back in and select the trailer the sensors are installed in. Once I do that they instantly connect. Now that I know I need to do that I make it part of my routine when initially hitching up. Pulled about a half dozen times and the system works flawless.
I use that work around also. But I think the OP is saying he can't do the initial pairing to the trailer tires at all.
