P0441 Evap control system error
Clayinfl
Tampa, Fl
My 2023 2500 threw this error code. Has anyone else run into this? Search gave me no results here.
A P0441 code on a Ram 2500 indicates an "
Evaporative Emission (EVAP) Control System Incorrect Purge Flow," often caused by a faulty purge valve solenoid sticking open or closed, leading to improper fuel vapor management.
Ironically I got a JD Powers reliability survey on Saturday, CEL error on Sunday as soon as I submitted the survey.
Clay
The P0441 code means that the EVAP system is detecting an incorrect purge flow rate. In most cases, this is caused by a faulty or stuck open/closed EVAP purge valve, preventing the system from properly managing fuel vapors.
