I’m not real sure what the gap is prior. I never paid attention to them until I put the camper on. I’ll be removing the camper in the next day or two so I will check then. I think it was around an inch before I put in alt height mode but it already had the camper on at that point and failed to raise it to full height when the warning light came on.
Let me measure my gap tonight, but I think you want it less than an inch so that when the truck lowers an inch in alternate ride height a fair amount of weight is on the overloads before the airbags start supporting it again. My 2018 took about 500lbs in the bed to engage alt and my 2022 takes closer to 750lbs.
If it’s the same spring pack as a DRW then we know it’s capable of taking the extra weight, just because of the SRW they de-rate the max GVWR for DOT purposes. What is the difference between SRW and DRW max GVWR, 1600 lbs? All that extra weight must be in the RAW I would assume.
The FAWR is the same but the RAWR is 2,750 lbs more, even thou the GVWR is only 2,200lbs more than a CCSB and 1,700lbs more than a CCLB.
Even on the SRW FAWR+RAWR > GVWR.
