I finally installed my ARB Twin compressor that I had on my last 2500 in this one. I left my wiring harness in the other truck when I traded it so I made up new cable sets which took a while but are perfectly cut to the right length. In my last 2500 I had the compressor mounted behind the rear seats. This time I installed in the Ram Box and ran all the wires out the drain plug to the battery on the driver side which is also where the wiring is to wire it up to the Aux switches. I also decided to put in the air tank for running the impact wrench to change tires on the truck or trailer. Last year I had two trailer flats within 5 miles - so I like to be prepared in the tire changing department!
