Oil
TGretter_15
Just got a 2015 2500. Is there a big difference Between the 0w40 recommended oil vs 5w40? I cannot find 0w40 in stores around me so I’d have to buy online. Curious about everyone’s opinion on this. Thank you
You can run 15 -40 regular oil or 5-40 , 10-30 synthetic . 0-40 is not mentioned in the manual from what I have read . I have never seen 0-40 heavy duty oil sold . You should pull some old oil out or if possible ask the previous owner what oil they used and go from there .
Like Nick says above, 5W40 is the recommended weight for cold weather. 15W40 is recommended for above 0 degrees F.
You guys posting above answers are correct for a Diesel, but original poster is looking for information about a Hemi. Personally I only use the 0W40 called for in the owners manual, and yes I also have to order it everytime.
0w40 is more for us canadian folk in the winter they do sell shell t6 diesel 0w40 we run it in the powerjoke at work as it does not like 5w40 in the winter
Run the 0w40 and order it if needed there is a reason they call for it
0-40 I mainly for fuel mileage . My wife’s car 0-20 you run 5 to 10 -40 you will probably not notice any difference in mileage .
Get an oil analysis it will tell you the difference you do not notice…
oil viscosity is important to follow properly unless you like wiping out an engine early…
I had to order 0W40 Penzoil Ultra from Amazon. I couldn’t find it anywhere. I could find 0W40 for European vehicles but it doesn’t meet the requirements given for the 6.4.
Even though I used the correct oil, it still showed a P1521 code, incorrect oil used, when I took it to the dealer. The truck sits in the driveway for extended periods, 3 week this time, and I pretty much only drive it when towing. I started it yesterday and it sounder like a lifter was coming out the of the engine. i turned it off and restarted again and same thing. called the dealer and told them I was bringing it in, still index the CPO warranty. Started it again after getting off the phone, quiet as a church mouse. Took it in anyway just to be checked out. They called today and said it was showing a P1521 code, wrong oil, and wanted to do an oil change. The last oil change was May 25th, less that 1000 miles. i told them to go ahead even though I know I used the correct oil and Mopar filter. We’ll see what happens. I’m afraid they will try to void any warranty claims.
