Oil Filter examination - lets see yours !
Army19kilo
My new 2024 2500 Rebel had alot of tick...lifter tick, All my hemis have ticked at startup that went away in short time, but this one is very different...Tick was remaining longer and louder after starting the truck and wasn't completely going away. It had been to dealer for the first two oil changes at around 6000, I now wish I would have changed the oil a little sooner. For the third oil change I used some M1 FS I had in the garage ( 0-40 ), after that change and around 2000 miles it was ticking loud enough that I didn't want to drive it until I had the dealer inspect it. I took it down to the dealer and left it overnight so they could hear the cold start-up with me present....they both heard the loud ticking. I was there to cut open the filter and get an oil sample, but the tech said he would return the filter and grab my sample for me, I said okay fine. They ended up writing it up as "we started another vehicle with the same year motor and it sounded the same" ...ahhh okay thanks guys ! needless to say Im not really happy with their diagnoses.
I cut that filter open the following day and found some small metal galling in the filter, not much but they were there. It would take about 3-5 min to find a piece of metal with an eye loop. So I'm keeping that filter but I am unsure if this is normal or not. Truck has a 5 year 60,000 mile warranty.
Okay why am I cutting open the oil filter??, well my other truck is a 2014 Ram 2500 tradesman and last year all of a sudden I had what sounded like a collapsed lifter, it just came on suddenly. I ended up taking it to the dealer for diagnoses, they found metal in the VVT solenoid, and I decided to replace the long block. $12000 later i basically have PTSD form this event so I originally ordered the oil filter analysis kit from Blackstone for this 2014 Ram. Well I did the first oil change on the 2014 a few weeks ago and cut the filter open and left it on the bench to drain. This morning i picked it up to cut the filter media off. It was then I already noticed metal flakes on the paper towel I had it sitting on. I cut it open and took it inside put it on the kitchen table on some new thick paper towels and stretched it out. Holy crap this thing is loaded with metal flake at only 1814 miles !
Okay hence why I am initiating this thread...i would like to see what is "Normal" from Ram HD 6.4 owners. I will put up pictures of my 2014 filter ...let me know if you think this is "Normal" and cut your filters open lets see what you have.
The pictures below unfortunately do not show the entire filter but just about every pleat has metal in it.IMG_9513.JPGIMG_9514.JPGIMG_9515.JPG
For reference I used an oil filter cutter I bought off amazon for around $20 that utilizes a cutting wheel similar to a pipe cutter or kitchen can opener.
( I tried uploading the video ... it was a no-go )
Ken -= Penfield NY
A tick that goes away after a few seconds of running is normal and usually a byproduct of an oil filter with an inferior anti-drain-back valve. Using a good filter like WIX or Fram Titanium negates this to a large extent.
A tick that seems to go away after 2-3 minutes of warm up time can manifest from a warped exhaust manifold leaking. Usually the thermal expansion of the head and manifold seal these guys up after running for a bit - though if really bad it can continue. Usually associated with an exhaust smell in the engine bay.
The typewriter noise all 6.4's make is normal. Usually quiets down after running for a bit.
A tick that doesn't go away with warm up or gets louder is the bad news bears tick.
With that new engine filter if you've got that much metal in the filter after sub-2k miles I'd be taking it back to the dealer ASAP. Was it a MOPAR long block or some garbage like Jasper?
Yes Mopar short block installed by Ram dealership ( 2014 Ram ), with Penzoil Ultra Platinum with mopar 399 filter the filter below is from that truck with 1800 miles on the motor...all my 5.7s and 6.4s would tick at startup for less then a minute and usually be gone in about 10-20 seconds. I have had the 5.7 break rear exhaust bolts twice... so I am familiar with the different noises associated with those failures... the new Rebel 2500 with the 6.4 is definitely a lifter tick and had much less metal in the filter at 20000 miles.
I would love to see others post pictures of their filters at the first oil change... I had a couple people say it's normal for the first couple oil changes so I am not sure but could be normal break-in wear or maybe casting machine debris.
Out of curiosity, if you run 91 octane gasoline, does the tick noise level go down ?
I did run the higher octane for a cpl tank fulls , but I did not notice a huge difference with anything , but that was at least five thousand miles ago or so, anyhow, I have been wanting to try that again but I think I'm gonna try to stick to that for a while when i do it to see if mileage/conditions improve enough to warrant the extra cost, also i've heard that stumbling idle can clear up too. This truck is new, but I do notice a little bit of a stumble in the idle , like I have in all my Hemis.
And actually, the tick noise level did go down after the last oil change with Pennzoil.Ultra platinum, but you can still hear it, it's not completely gone
Octane would make no difference to any of the typical Hemi ticks.
I have seen people report both ways on various ram engines including the hemi. My understanding is that the tick is pre-ignition and that is reduced by using higher octane fuel. Pre-ignition is damaging to engines. My belief is that that ram is designing the engines right on the edge to keep agencies and accountants happy, and fuel companies are doing the same thing.
It is an easy fix / tick reduction if it works.
All versions of Hemi “tick” happen at both idle and under load to varying degrees and depending on temperature/run-time. If you are getting pre ignition at idle you’ve got more serious problems afoot. Internet lore abounds.
