I’m looking to install a Fumoto oil drain valve during my next oil change, to make future oil changes less messy. Any recommendation for which “version” to get? https://www.fumotooildrainvalve.com/cars-pickups-ram-2019-2500-6-4l-v8
I use Fumoto on everything have for the last 10 years. Heavy equipment comes with them from the factory, so do be concerned about having a valve for a drain.
Get the hose nipple version you will never have oil splash from the pan ever again. Only down side is that it does drain a little slower.
I put fumoto valves in everything I own with a drain plug. No mess, simple to use and nothing but a drain pan goes under the truck with me. Not a drop of oil on the driveway.
After purchasing the EZ Flow FTV-104A oil drain from Geno’s Garage and after installing it on my 2022 3500 with 1668 miles, but before filling the truck I was not really thrilled with the very small thin flange that tightens against the pan so I removed it and reinstalled the OEM pan bolt. I...
