First time posting. Fantastic information and expertise on the site. I visit often.
My 2024 2500 Laramie didn't have the bed lights installed from the factory, so I decided to install the Mopar/OEM kit myself. Install went fine, but I can't get the lights to turn on when the in-cab cargo lamp is switched on, the bed switch is pressed or when the tailgate opens. The third brake cargo light can be switched off with the bed switch, but that is it.
Per the instructions, I tied off the short tan/white wire, attached the green/white wire to pin 16 of the under dash C7(G) connector and the long tan/white wire to C3 pin 17 connector under the hood. There was already a tan/white wire installed, which I pulled and taped off.
Using Vlinker+ and a security bypass cable that Florotory built for me, I activated both "Bed Light Switch Input Present" (BCM Pin G16) and "Bed Lighting Present" (BCM Pin A5) in Adaptation Settings (Run position). After the change, I shut off the ignition, locked the doors, made sure the key fobs were far away from the truck and waited 10 minutes. Under the "Trace and Restore Adaptations" section, I can see the both the changes as "active". But, no lights in the bed.
Since JScan lists the Bed Lighting Present connection as BCM Pin A5, I decided to try inserting the tan/white wire into Pin 5 of the C1 (A) connector under the dash and the lights came on when the engine was running and shut off when the engine was off, but otherwise that was it. So I know the problem isn't with defective lights or the wiring/connections from bed. I also switched the adaptations on and off a few times, using the same process as before. Still no lights.
I assume the Bed Light Switch (Pin G16) connection is working, since it turns off the third brake light cargo lamp. So, the problem must be with the C3 Pin 17 connection under the hood.
Infotainment has an install video on YouTube which has some good information (I didn't use thier kit, just watched the video) They didn't connect the long tan wire and instead plugged the short tan/white wire into Pin 5 of the C6 (F) connector. I guess it worked for them, but I haven't tried it since getting to the C6 connector is a huge pain the ass.
Any suggestions on how I go about diagnosing the issue?
Thanks much,
Thanks much,
