Its how its listed on the EL.I’m a bit confused? You mean an aftermarket cushion? All of the models use the same seat foam to my knowledge, just different configurations and cover materials.
The seat foam is different if it has ventilated seats. Is Laramie the only model that can be optioned with either heated, or heated/ventilated seats?Laramie is the only model I see that even lists a cushion type on the equipment listing
#1 Seat Foam Cushion
I checked ELs for a Laramie, Limited, Tradesman, Bighorn and Longhorn. I don’t think it means anything.
Good point. Same foam though? Just has holes for ventilation.The seat foam is different if it has ventilated seats. Is Laramie the only model that can be optioned with either heated, or heated/ventilated seats?
No, different foam all together because it has to accommodate the ventilation bag.Good point. Same foam though? Just has holes for ventilation.
