chris61530
I have a 21 3500 ho Cummins. I have been hearing this noise at idle. Can't pinpoint it. Dealer did a reflash still there. Had anyone come across this before?
Agreed, I'd pop the belt off the tensioner and check its pulley/bearing first.... They are kinda known for going first and easy to check yourself.sounds like a bad bearing in a pulley
You likely could but it could throw codes, not charging.. EtcDid you solve this? Could you run it with the belt off to see if it's internal?
drive.google.com
