No fuel going to front filter after change, wont start
If no blockage on the rear, should I try to prime it longer than usual? Without trying to start. Like 6 times.turn on for 15.seconds, off for 10 seconds?
Turn key on wait 30 seconds then off do that 5 times it will be primed if not you have other issues
You didn't leave the front drain open and it's pouring fuel on the ground?
No. No fuel.going to front filter, no leaking anywhere. Dealership cant even look at it until.Feb 2nd. I have to move my rv on Sunday and move a friends on Monday. Dealership thinks a.sensor or a clog. I am thinking a computer reset at this time which I dont know how to do. Or a clog. But all was fine before.the new filters. I did.the change as I always have. The only thing different are the 2 filters. Nothing is working. UGH!
Put the old filter back on the rear and see if it works
Did you put an old filter on yet?
You say nothing is working, does that mean you don't hear the lift pump?
Computer reset won't do anything if the pump is running.
If the pump isn't running have you checked fuses?
I just got off the phone with a friend of mine. He had his filters changed and the truck wouldn't start.
Turns out the "OEM" filter he got off Amazon is a fake and the plastic piece that opens the check valve when fully seated doesn't open... which is the cause of the no start condition.
Buyer beware.
Buyer beware.
Lots of that lately beware of scamazon!
