I am guessing you are talking about 285/75-18 and ridge grapplers. both will be less than what they say. I run Toyo R/T in 35x12.5-17 and my buddy runs RidgeGrapplers in the same size both on AEV salta wheels. Mine are slightly bigger than his when measuring with a tape measure. Both taller and wider yet visually his looks bigger. It is weird but the tape shows it is an optical illusion. I have run AT3 Toyos in 35's and they were slightly short. so it kind of depends on models. My buddy ran 285/75-18 in RT's and they are bigger (taller) than most 35's. Not sure what truck you have but I like the R/T's better than I liked the AT3's. Only advantage the AT3 would have would be on ice. they were stone catchers for sure so if you do a lot of gravel they fling rocks like crazy. I just helped him rotate his tires yesterday and it looks like mine are wearing better as well. We have the same amount of miles and are rigs are set up similar.Looking at running LT185/75R 18. Read that toyo runs shorter than advertised and nitto true to size. Nitto runs about 4 1/2 lbs per tire more. Don't know if that is a deal breaker. Anyone running these care to share info? Thanks
I am running the Ridge Grapplers in the 285/75/18 size on 18x9 Method wheels on my 2021 3500 SRW.they are just shy of 35” at 60 PSI. 7500 miles so far and very happy with them. That size will fit underneath as a spare also.Looking at running LT185/75R 18. Read that toyo runs shorter than advertised and nitto true to size. Nitto runs about 4 1/2 lbs per tire more. Don't know if that is a deal breaker. Anyone running these care to share info? Thanks
That's good to hear. Is your suspension stock? Any rubbing issues?I am running the Ridge Grapplers in the 285/75/18 size on 18x9 Method wheels on my 2021 3500 SRW.they are just shy of 35” at 60 PSI. 7500 miles so far and very happy with them. That size will fit underneath as a spare also.
No. But the wheels are already very tight on the hubs. Method wheels.OK Thanks. The wheels I'm looking at are + 18 also. Are you using hubcentric rings?
Very nice.NITTO Ridge Grappler 35x12.5R18 Load F Method MR305 18x9 +18 offset
