NHTSA Recall 26V-059 Trailer Brakes
mmeyer
I bought a 2026 2500 Laramie Diesel. I just got a recall stating the Trailer module has issues. I called to get an appointment, and they said they do not have the parts yet. I asked if its safe to pull a trailer. They said, they couldn't say. Does anyone know what's going on? How does one buy a $100,000.00 truck and not be able to haul and have no information on when it can be fixed.
Hello there, @mmeyer!
For us to better assist and ensure we're reviewing the correct recall for you, please send a private message our way with your VIN. We're here to help!
Hannah
Ram Cares
I have a '25 with the same recall, but as of now my lights work fine and I will pull the 5TH wheel without reservation. My guess if you are going to have issues, you are already having them.
Our invite still stands for you as well, @jetlag if you decide to pay your dealership a visit.
Hannah
Ram Cares
Once parts are available and an appointment is set, we're here to help, @jetlag! Alternatively, we can also formally document any additional comments for reference in preparation for a future appointment.
Hannah
Ram Cares
I have this same towing module recall on my '26 2500 6.4.
If you have actually had this recall done, please tell me how long it took, and what the process was.
I'm on a snowbird trip, need to pull my trailer to another location soon, and the local dealer isn't following through, I don't even know if they have the part, and they want me to drive 40 miles one-way to an appointment.
Also, I have a lot of equipment in the rear seat and the box, and I'd like to find out what, if anything, needs to be removed so they can do the job.
Any information appreciated,
Thanks!!!!
I had issues with my trailer brakes and lights. You get a warning on the dash I believe it says trailer system fault see dealer something along those lines. I cleared default with a scan tool at a friend shop. Warning didn’t come back for another 2000 miles. Cleared the code hasn’t come back again. I did take it into the dealer and they said they couldn’t find an issue. This was before the recall came out. The first time there was a fault you couldn’t adjust the Trailer gain up or down, the second time there was a fault when you squeezed the trailer brake controller, Nothing happened. Both times the trailer breaks actuated, but the lights didn’t work correctly. Still waiting on the recall to be done, but I haven’t had any issues. Just under 14,000 miles on the truck now most of what which are towing.
My dealer FINALLY has the part in after hounding them for over a month. I'm getting it replaced on the 18th, told it should be done in a few hours. I'll report back after and share how it went.
Recall done, left the truck with the dealer for the day. So far, no problems with it recognizing the trailer and working as it should.
Good to hear, @RebelForge!
Know if you have any additional follow up questions our team is here to listen and offer assistance.
Hannah
Ram Cares
It may seem like an odd question but where is the tow module located? I thought I saw somewhere that it's on the wall behind the backseat?
Found the location in the other thread, behind driver's side rear seat.
I was just at the dealer to get the SCCM replaced in my 26 2500...they didn't mention this recall. Is it EVERY 2025/2026 or just a select amount made during a certain period?
I was dropping my truck off at the dealer today, the service writer told me that a work around if your brake controller is not working is to hook the trailer up and remote start the truck. Of course once you turn the truck off you may have to repeat the process if the controller is acting up.
Ford has this same recall but it was a software update for the fix...to bad it wasn't that for the Rams.
