New to ram and the new Cummins.
Ievko82
Just picked up a new 24 ram 3500 with the HO Cummins. Anything to keep in mind, Are there additives I should be using or things I should or shouldn’t be doing? My last Cummins was a common rail that all I had to do was the regular maintenance and it ran fine.
No, nothing special. Just note that today's Ram Cummins are made to pull. If you use it to commute, you may eventually have frequent regen issues. Tranny fluid change on the Aisin trans is at 30K miles. My truck tends to sit for 2-4 weeks between uses, so I use some Howe's on the last fill after a trip. That's the only additive I've ever used in it.
