New Morimoto XB Hybrid Headlight Install Help
So I'm installing my new MM Hybrid LED headlights and have a few questions.
First is how high should the light line be for a bone stock truck from ? X feet away? I was to eager and forgot to measure lights prior to removal.
Second question is on the adjustable mount on the bottom (screw the base in or out) I think the passenger one got moved, should I just set these all the way in?
Lastly, the main adjustment screws look pretty accessible from the bottom side of the truck, if there is any other tips I'm all ears.
Thanks.
I installed these same MM Hybrid LED headlights. Not sure if you read that these come out of the box pre-aimed to factory specs. However, if you've got any front-end leveling/lift, then I guess you'd probably need to adjust them.
Thanks, I didn't know that. Its completely stock so hopefully its done and I dont have to mess with it then. Now on to my fuel leak issue
