New Member - 2016 ram 1500 laramie.
Hed$up25
Air Suspension is having it's way with me, I recently changed out the cv axles and hub assemblies. Drove it about 170 miles, picked up my boat etc... Then the Service air ride message started to appear. I got it in the garage and started checking the usual suspects (fuses, relays, leaks etc) I hook up the computer and its got codes for the wheel speed sensors on both front wheels, ABS, and a couple others. erased codes, checked the sensor wires and connectors for damage, started running diagnostics with the scanner, and it goes into plant mode and drains the resevoir and bags the whole system. now all four ride hight control lights are flashing and all I get is "low air mass" message when I try to adjust the hieght. Jumped the compressor relay, and it runs but the level doesn't change.
