New Forged Wheel!?!
johanh13
Texas
Check it out guys, this is the closest I have found to my [perfect] specs. This may be my next wheel....
  • Forged 6061 Aluminum.
  • 100% USA Made.
  • Pronounced Bead hook, for running Low-Pressure more safely.
  • 8" x 6.5" Lug Pattern.
  • 18" x 9" +20mm Offset.
  • 5300lb Weight Rating.
  • 39lbs.
  • Hub-Centric for Ram 8 Lug Single Rear Wheel Trucks.
  • Valve-Stem impact/Rock protection built into the design.
  • Supercar level Runout quality.
  • Uses OEM or Aftermarket lug nuts
I don't think you will find a forged wheel in an 18" for HD anywhere for less... compare to TR forged, Battle Born & Innov8... Innov8's 17x8.5" is $749, TR's & Battle Born's are $850 in 17x8.5", all in plain aluminum finish
I really like the polished look, but I don't think I could do the work... so will likely get the shadow black. What would you get for a white limited ?
