Need Help with AlfaOBD
genxeration
I was trying to help my brother disable BMS on his 2020 RAM 3500 after he installed a service bed. I installed the bypass and purchased an AlphaODB subscription. I disabled everything related to blindspot monitoring and the message on his dash went away but now he has no audio. We reset his uconnect and disconnected the two battery cables to reset BCM. Still no luck. Any ideas what I did wrong?
We’ll need to know what you did before we can tell you if you did anything wrong.
Also, it’s AlfaOBD as in Alfa Romeo.
Thanks. I went into the section car configuration change and I searched for "blind". Anything that referenced blind spot I disabled it. I'm thinking maybe I should go back and enable everything related to blind spot and see if ti starts working again. And No, I didn't create a backup. Man I wish I would have though!
Here's the items with "blind" in the name that were set on my 2020 that had BSM enabled:
VehConfig 7:
Active Blind Spot Present: No
Doors:
Blindspot Mirror Present: Yes
Cust.Set.Menu 1:
Blind Spot Alert CSM Present: Yes
Cust.Set.Menu 2:
Teen Key Blind Spot CSM Present: No
Blind Spot with Trailer CSM Present: No
Blind Spot Warning CSM Present: No
Active Blind Spot Enable/Disable CSM Present: No
Active Blind Spot Warning Mode CSM Present: No
Active Blind Spot Sensitivity CSM Present: No
Active Blind Spot Strength CSM Present: No
Active Blind Spot Haptic CSM Present: No
Cust.Set.Menu 3:
Trailer Length Blind Spot Enable/Disable CSM Present: Yes
Cabin Net:
RBSM Right Blind Spot Module: Enabled
BSS Blind-Spot Sensor/LBSS Left Blind-Spot Sensor: Enabled
VehConfig 7:
Doors:
Cust.Set.Menu 1:
Cust.Set.Menu 2:
Cust.Set.Menu 3:
Cabin Net:
I appreciate it! I’m wondering if disabling blindspot alert could have disabled an audio channel or something weird like that.
I'm helping my brother with his 2020 Ram 3500 dually. He removed the factory bed and had a service bed installed. We're trying to use AlfaOBD to get rid of the DTCs. On the dash we're seeing Rear ParkSense Unavailable Service Required and BlindSpot Alert Unavailable. The codes I'm seeing in AlfOBD are fault codes U0232, B16E7, B1642, and B1646. Anyone know what I need to modify to get rid of these? I really appreciate any information and thanks in advance.
