jwhorner
I have a 2020 2500 Tradesman. I've upgraded the stereo equipment and recently just had an amplifier and processor added. It worked fine until a few weeks after install. 2 days ago I got in and the radio, HVAC, front windows, and blind spot monitoring were non-functional. Here's the interesting part the windows and radio work fine when the truck is in Accessory mode but when I turn the ignition on the radio shows the screen it does when you would typically turn the truck off, the Ram name comes up and then fades away with a line to appear like you've just turned off your truck. The radio is non-functioning then as well as the aforementioned components.
Thoughts?? What is different between Accessory and Ignition? Power from the battery under Accessory mode but where during running? I've been hunting and been on some bumpy roads, could something have come loose? I know I'll have to take it in somewhere to have diagnosed but wanted to check here first. Thanks!
J
J
