I've had a number of different electric compressors over the years and have always been frustrated with them. They've been slow, loud, and many didn't last long. So, I decided to do something different and get an engine driven one this time. I had considered the 12v Oasis compressor, but price and the difficulty of finding a mounting space lead my back to the Outback ExtremeFlow compressor. Compared to the electric compressors I have had, this is very quiet. It can barely be noticed over the idling engine.
I installed the Outback ExtremeFlow Belt Drive compressor nearly four months ago, but wanted to make sure I was happy with it before sharing my experience. I have only put about 2k miles on the setup, including a 1100 mile trip without issue, but I am very happy with it. The compressor itself has a total of about 40 minutes of runtime so far. The install wasn't too bad but took a couple of tries to get everything like it should be due to some small changes on the 2022 we weren't aware of.
I spoke with George at Extreme Outback and ordered their ExtremeFlow Belt Drive Compressor and Mounting Kit for the Ram. He was very helpful throughout the installation process. The mounting brackets were heavy duty, all the holes lined up, and belt was well aligned with the compressor. The unexpected issues were the need to extend the power steering pump supply line from the reservoir by 1.5 inched to clear the compressor, reroute a small PS return line to the reservoir to prevent rubbing, and getting a 132.5" belt. The belt originally sent in the kit was a 130.5", which was too short, even with the smaller idler pully sent for variations in prior years. So evidently, in 2022 there was another small change to the belt area, which caused a little grief. I had both intake and exhaust lines come directly out of the compressor without using the included right angle fitting to give more clearance around intake horn piping. The intake sucks filtered air from the factory air box, and the exhaust line runs to a 3 gallon tank under the driver's side door.
0-150 Compressor Performance with 3 Gallon Tank ( CFM was calculated over the 0-150psi range using the time, so it could be off )
https://www.extremeoutback.com/product/belt-drive-compressor-mounting-kit/
- Idle 43 seconds - Averaged about 5.7 cfm
- 1100 rpm 34 seconds - Averaged about 7.2 cfm
- 1500 rpm 29 seconds - Averaged about 9.2 cfm
