elephantrider
Hydraulic Lifter Crew
I've gained 40jp just from the extra turbo sounds.
Highly interested. But their website doesn't mention 2020 RAM trucks. Guess I'll call.I'm running the emissions intact CTT tunes, keeps the EGR closed and no longer uses DEF, truck still regens just uses no DEF plus I'm not circulating all those exhaust gasses and crap back through my motor.
Stock exhaust and intake, all stock except the tune, I'm running on level 2 tune on #3 fueling and I'm getting 20 -21 mpg if I keep it under 75.
20 3500 SRW HO with Aisin
This is where you would go to order https://ordtuning.ca/shopHighly interested. But their website doesn't mention 2020 RAM trucks. Guess I'll call.
I'm using the EZ Lynk as the means to load the tunes and monitor parameters.
Top Gun Diesel can get you hooked up, give him a call.. https://topgundieselperformance.com/
His truck probobly has the SO cam.Good info, thanks for sharing. That mpg, if accurate, is impressive on an HO.
