SNJerz
Looking to see if anybody has any experience with these good or bad??
Hopefully the issues don’t extend to the pan. I mainly got it for the drain plug and the thicker flange. Planning on using a gasket (never been a big fan of RTV). I’m mainly going to be towing about 7500lbs with maybe 600-700lbs in the bed of gear. Lots of long trips through the hills in PA,NY, and northern NJ. Should be a walk in the park for it.Not specific to the 68RFE pan, but lots of reports of Mishimoto quality control issues over the years.
Unless you spend a lot of time with the torque converter unlocked it’s unlikely you’ll see much of a difference in temps or get much added benefit from the added volume.
I tow roughly 10,000lbs worth of toy hauler through NNJ, PA, and down through the mountains in VA & VW. Often times I'm towing with 35" or bigger tires. So far my trans temps have always stayed under 190. There was one time, I had to crawl up a steep hill with a nasty hairpin in it in 1st gear, then my trans temp got a little hot & peaked around 208, but that was the highest I ever saw them go. I also plow with this truck and again never see the trans temps crack 190 while plowing.Hopefully the issues don’t extend to the pan. I mainly got it for the drain plug and the thicker flange. Planning on using a gasket (never been a big fan of RTV). I’m mainly going to be towing about 7500lbs with maybe 600-700lbs in the bed of gear. Lots of long trips through the hills in PA,NY, and northern NJ. Should be a walk in the park for it.
I think the pan is where I draw the line for the time being. I have the 4 year/48000 mile powertrain warranty from MOPAR so not trying to make too many mods. I saw the bypass from a few companies and saw some of the differences it made were impressive. Also saw the mishimoto one with the removable thermostat for summer. Definitely on my radar post warranty period.
The thermal bypass on my truck opens at 168*. I’ve never seen the temperature get over 174* towing 7.5k in 116* temperature around Abilene, Tx. at 70-75 mph. 2022 2500 with 68rfe.I cant remember what Pan my guy installed but when i switched to a oversized pan, I saw a small temp drop. Now doing some heavy towing it wont matter you will need a better cooler. The inline thermal Valve still doesnt open till 180deg. People are switching to an aftermarket bypass, but pay attention to that your trans can run too cold. Mishimoto has a nice one where you can switch it back and fourth and should open 10deg cooler than OEM.
Yeah this time of year the trans temp would never get up to operating temperature without it. It’s slow getting up to temperature even with it in there. I do plan to change the pan on mine at the first fluid and filter change just to get the drain plug.I was thinking it was the same temp as my Aisin, which usually runs 163-165°. I’ve seen it above 190°, but only after long 1st gear pulls above 20K GCW.
Just don’t see the need for the modified l/removed thermal bypass, they are there for good reason.
