*** Member is MIA *** GODZMFG.COM - Ongoing F/S Thread w/ Member Discount!!!
[MOD: GODZ_MFG is considered MIA as they haven't been responding to anyone.]
A couple of new products for those of you who are scared of the dark!
We recently released our brand new front bumper light mount for the 2010-2018 RAM HD trucks as well as the 2019+ RAM HD trucks. This product has come to be so you all have a better solution for securely mounting up to 5 off road lights on the front of your trucks. We wanted to provide you guys with a secure mounting solution the installs simply and looks amazing.
Here’s why we’re excited about it:
  • Durability is Key: We constructed this beast from 1.75" DOM Tubing, ensuring it can handle whatever your adventures throw at it. Plus, it's fully welded for that extra durability we all need when hitting the trails hard.
  • Custom Fit for Your Rig: With custom laser-cut mounting brackets your lights will fit perfectly, providing optimal illumination. It’s all about making sure you have the visibility you need, exactly where you need it.
  • Battling the Elements: We've all been there, dealing with rust and wear from the harsh conditions our adventures expose us to. That’s why we’ve added an extensive finishing process, including sandblasting and powder coating, to keep your mount looking fresh and functional for years. And those push-in caps? They're not just for looks; they keep everything neat and tidy.
  • Easy Installation: We know your time is valuable. That’s why this mount is designed to bolt directly into OEM mounting locations using the original hardware. Simple, straightforward, and no weekend-long install projects.
  • Proudly Made in Colorado: From design to powder coating, every step is done right here, ensuring quality and craftsmanship you can trust.
And don’t worry, we’ve thought about the tech too – this mount won’t interfere with your factory Parking Sensors or any winch funtionality found on the Power Wagons, maintaining all your vehicle's functionalities.
If you’re ready to take your off-road lighting to the next level and support local craftsmanship, our 'GODZ MFG RAM 2019+ 2500/3500 FRONT BUMPER LIGHT BAR MOUNT' might just be what you’ve been searching for. Let’s light up those trails together!
Stay adventurous!
4TH GEN LIGHT MOUNT:
5TH GEN LIGHT MOUNT:
I just wanted to throw out there that if you were to make a dead pedal I bet a lot of people would be very interested in it.
Anyone have a GODZ Tailgate Bar Lamp Kit they’re willing to part with? I’m trying to find a lamp bar kit that will work like this one and am having no luck. No other lights come with the t-harness like this one. MOPAR brand lights apparently don’t fit the 2500’s. Assuming it’s because they don’t come pre installed with the correct wiring harness that will accept this light without the need for the t-harness. Any help is appreciated.
All you need is the MOPAR light, the Curt 7-pin pigtail of choice (they come in 4-pin, 5-pin, etc., a couple 2 pin connectors of your choosing, and the bed inserts. It's not PNP, you just have to assemble it yourself.
Would something like this work?
Probably, but you would still need to look at the wiring diagram and source the mating connector for the LED bar. Looks to be a Deutsch 4-Pin on the Diode Dynamics cable. I also saw reference that depending on hookup, this may trigger the truck to believe there's a trailer connected. I expect if you isolate the running light only for the LED bar (as I and others have done with the Curt Y-cable) it will be OK.
