Mega Cab Sub Installs - Photos and specs wanted
TXLaramie
All, as the title states, I am looking to see what everyone has done in the way of a subwoofer(s) install for the 5th Gen Mega. My goal would be to keep the most space in the rear, likely remove the alpine factory sub to make that room. I have only seen a single system that meets this, but it has (3) 8" subs. I would like to go with (2) 10" or a single 12"...as original poster stated and as I have seen in the past the 8" subs just don't cut it to hit all frequencies.
Thanks everyone for your help here!
Older post but might help OP or someone else searching ..
Saw this on the fox acoustics website. Thinking about it for our Mega when it arrives. .
DODGE RAM MEGA CAB 2-12" SEALED DOWNFIRE
RAM MEGA CAB
DMC-212-S
FITS ALL YEARS OF MEGA CABS
2006-2022
2-12" DOWN FIRE SEALED SUB BOX
SUB SIZE: 12"
SUB HOLE SIZE: 11.15"
MOUNTING DEPTH: 7"
MAX MAGNET DIAMETER: 6.5"
INTERNAL AIR VOLUME: 1.1 FT3 PER SUB
SUB BOX IS NOW A 2 PIECE DESIGN "DRIVER AND PASSENGER SIDE"
12" to 10" adapter ring available if you want to use a 10" sub.
FACTORY IN FLOOR STORAGE COMPARTMENTS AND FLAP MUST BE REMOVED.
TOP OF BOX CAN BE USED TO STORE CARGO ON.
SEATS WILL STILL RECLINE TO A 30 DEG ANGLE.
Subs with large diameter frames will require trimming of the opening by the installer.
RAM MEGA CAB
DMC-212-S
2006-2022
SUB SIZE: 12"
MOUNTING DEPTH: 7"
Wish the flap was still there to keep from items falling down between box and seats, but this looks like the best option outside of a custom made box from one of the local audio shops.
Thanks for the post. I haven't made it to upgrading anything audio yet. Hopefully early 2022 after I get the suspension done with Thuren or Carli level.
