Marker/Parking lights Bighorn with OEM LED
HDKnox0683
New here and just bought a 22 bighorn slightly used and it has the factory LED light package. I noticed when the headlights are on there are no marker/parking lights illuminatied like on the bighorn trucks without the factory LED lights. I am i missing something or are they no supposed to burn except when the turn signal is on? Im noticing bighorn and tradesmen trucks with halogen lights do. Thanks.
The orange lights should only be on when the night lights (park lights) are on. Are the tail lights on?
Check the fuses, you never know what the old owner did
I’ll use your profile pic as an example.
The three arrows are pointing to the marker/parking lamps on the LED headlights. Are you saying those aren’t coming on (like they are in your pic) when you turn the headlights on?
The way your pic is right now, the headlights are on and markers/parking lights are functioning the way they should be.
The turn signal is pointed out below, and only functions as the turn signal is being used:
Ok. Working as described above I was just surprised that there was no amber on the front and as mentioned above the regular bighorn it is illuminated when the headlights are on. Thank you.
