engweld22
I have a 2023 2500 Cummins with 71k miles. I went to start the truck up the other day and it started, i ran it around town came back and shut it down. Went to go start it up again and it cranked until i hit the start button again. I did the method for priming the fuel system after changing filters, no sound from the fuel tank. I checked the fuse, it was fine. Swapped the fuse and tested again to double check. Didnt get it running again. I then let it sit for a week and i hopped in and i could hear the fuel pump whirring again. took it for a drive and it was fine. i had alpha going and recorded my fuel rail pressure and was getting 900-1000 bar, which is good, my HPFP is working. Shut the truck down, went to start it again and the fuel pump made no whirring sound and then it cranked and cranked and i shut it down. So i think my in-tank fuel pump is bad.
Can i get a recommendation for either going to an aftermarket fuel pump system or in-tank pump?
Since i may be dropping the tank if i go with an OEM equvivalent, would it be preduent to just replace it with a higher capacity tank and get the higher capacity fuel pump?
Thoughts, arguments?
