Location for mounting a relay
JMC66
I am going to run power to the rear of the truck and want to run it from the HAPP then through a relay that I will connect to an aux switch. I have a 2023 3500 with a 6.4. I am looking for a place to mount the relay and am not seeing any obvious area in the engine compartment. I have seen a few posts about others who have installed power through a relay but not seen any photos of where they put the relay. I am considering putting the relay on the frame rail just past the engine compartment. If anyone has a photo of where they found a spot for the relay it would be appreciated.
You mention aux switch, you’re not talking about the factory aux switches, right?
Relay or solinoide? A relay there is tons of room a soliniode can be mounted by the rad support
Ah, solenoid makes more sense with all that as with the factory aux switches all the relays are already under the hood.
I just looked that will work. Thanks I don't know why I overlooked that area.
