CastI-Iron
I just bought a 2019 Ram 2500 with the 6.4 hemi in it about 6 months ago. It is primary used for vacations towing our travel trailer - upgraded from a F150 ecoboost and I'd never go back. I've loved the stability and power of this truck.
Long story short, bought it with 114k miles on it but very low idle hours (Was at 460 or so when I bought it) but there isn't much of a history on it other than that.
It now has 470 idle hours, 2886 drive hours, and total mileage of 122000 - averages out to be about 42 mph. I was assuming it was mainly driven on the freeway.
Coming home from a trip after towing our travel trailer for several hours, right off the freeway I could hear the ticking in the cab. Changed the oil (was at about 4600 miles since I last changed it), and the oil filter is full of glitter. I've been using 0w40 PUP. After the oil change, took it around the block and now I'm getting misfires on cyl 3 and have a pending code (P0303). Luckily I caught it in time so the oil control valve screen is fairly clean when I inspected it.
The local dealership said it could be 5-6k to replace the lifters and cam. A local shop said it would be $6800. A third local shop said they don't do quotes like this over the phone because they don't know what else is going on in there, but last one they did was 9k+
I'm not sure if I'm comfortable with opening the engine myself because of everything that is involved with it - along with having to do this out in the elements. However I think I'd be willing to swap the entire engine assembly with a lower mile one. I can get a low mileage wrecked engine for about 6k. I'd specifically look for engines less than 30k miles. Obviously I'd want to be sure to look at how the truck was totaled.
What direction would you take? I could take on doing the lifters and cam myself, maybe delete the MDS system and put a 'grizzly' tow cam in it, but maybe it would better to start again with a low mileage engine and a high flow oil pump. Doing the lifters/cam myself would be the cheapest option, but I worry about what else I'd find when doing that job and having the truck sit in the elements while I carve out time to finish it. I don't know how many hours each job's 'flat rate' is either.
