Do you have the front plate bracket mounted? If so, those same screws also used to mount the plate and I use #14 x 3/4" for the rear.My truck is missing the screws for the license plates, both front and rear. Any chance someone knows what size they are ? Or could post a photo? TIA
Yes, I have the front bracket. so the screws that hold the bracket are the same as the ones used to secure the plate?Do you have the front plate bracket mounted? If so, those same screws also used to mount the plate and I use #14 x 3/4" for the rear.
Yes, if you have the factory mounting screws.Y
Thanks, that helps a lot!Yes, if you have the factory mounting screws.
